close connection ID TCP
I'm trying to create a communication client/server. I have achieved to establish the communication and to send messages between clients and server (like a "chat"). 1. My problem arise when I need close the program server. When I stop the VI it doesn't stop (I think the problem is in LOOP1). 2. In LOOP 2 of server I need a wait to run it slowly...why? TCP read timeout doesn't work? Thanks
Message 1 of 10
(3,999 Views)
Hi vicens,
it sounds like the vi hangs in the TCP listener. You can close the Listener Refnum to stop the the listener waiting on new connections.
If this doesn't help, then please show us your vi.
Mike
Message 2 of 10
(3,995 Views)
I forgot to attach VI! Vicen
Message 3 of 10
(3,988 Views)
this is the vi
Vicen
Message 4 of 10
(3,986 Views)
Hi Vicen,
it should work if you move the function to close the listener into the 3rd loop.
See the attached picture.
Mike
Message 5 of 10
(3,979 Views)
Thank you MikeS8,
The VI can to close it, but it occurs Error 1.
Is not important error?
Message 6 of 10
(3,959 Views)
Hi vicens,
where did you get this error? Can you upload your changed vi?
Mike
Message 7 of 10
(3,943 Views)
The vi changed runs good, but when I stop the program occurs Error 1 in loop1.
Vicens
WinXP LV7.1/10
Message 8 of 10
(3,940 Views)
Hi vicens,
the error is correct, because if you close the listener (what you do in loop 3), then the listener will result with an error and the output is "not a refnum", so you can't read data with the "read function". You can avoid it, if you check which error occurs from the listener and react on it. If you get an error, then you don't need to run the read funtion.
Mike
Message 9 of 10
(3,937 Views)
Ok Thank you very much. Vicens
Message 10 of 10
(3,935 Views)
