curious log-file growing on rt-target
Hi community,
I have a pxi-realtime-system that logs automatically multicast events from our network and creates a log file that becomes larger every minute.
The file is named packetsIn.log and appears under /ni-rt/system/ethernet.
The content of the file is
Source Mac: ...
Dest Mac: ...
PacketSize: ...
The mac-adresses that appear in the file are not the one of my controller but of some switches or multicast-adresses in our network.
If you delete the file, it appears again some seconds after that action. The file also grows, if no labview-application is running on the system.
Has anyone noticed a similar behaviour? What could cause this file-creation?
We're using LabVIEW 2009 SP1 and the curious is, that it only appears at one of our controllers.
Hope someone could help
gibbi
(2,318 Views)
Accepted by topic author Gibbi
Hi Gibbi,
please try to open the ni-rt.ini and set following entry:
[DEBUG]
RTPacketParsingEnbled=FALSE
After that the file should stop growing.
Best Regards,
Lam
(2,310 Views)
