close serial driver (Port 17)
Thanks.... but I don't think I have all of those VISA options on the 6.1 palette. If they were there it would of been obvious.
Anyway... I have managed to get it to work using Easy Visa Read & Write, with a slight modification made the the Visa(Old)Open command i.e I removed it.
I now have control of the ports required, and it has also solved my problem highlighted in my other thread.
Moral is to use Visa
Message 11 of 17
(1,118 Views)
I'm glad you got it to work. It's strange that the functions aren't on your palette. Do you have the default palette view turned? I also can't find Easy VISA Read and Write on my 6.1 installation. You were correct to delete VISA(old) Open. That's from a old version of VISA. You might want to check which version ov VISA is installed and upgrade.
Message 12 of 17
(1,113 Views)
When you say "The low level functions" you're talking about the yellow ones, right? Ones like Device control\status or Open Device? Are you saying they also use VISA? Interesting, I never thought about before. I do seem to recall KB articles as well as NI support personnels who suggested copying serpdrv into the machine even for programs that ran in 7. Oh, well...
___________________
Try to take over the world!
Message 13 of 17
(998 Views)
In my 7.0 installation at vi.lib\serial.llb, I don't have the little yellow ones. All I have is things like Bytes At Serial Port, Close Serial Driver, Serial Port Init, etc. and inside those are VISA functions. I don't have Fieldpont and I wonder if that's the difference.
Message 14 of 17
(991 Views)
I didn't say VI.lib\serial.llb. I said VI.lib\Instr\Serial.LLB. There I have the white ones (the old ones, the ones that work with port numbers) and in them I have the yellow ones (these yellow ones use a light blue wire refnum, similar to the TCP refnum). Anyway, looks like you're right, because I just checked on a third computer that has 7.1 with no Fieldpoint installed and the white ones I have there do use VISA internally and numerics externally.
___________________
Message 15 of 17
(988 Views)
I meant the path you mentioned. It's interesting about Fieldpoint though.
Message 16 of 17
(980 Views)
You also need to use a copy of the prior serial.LLB (from v6) and have serpdrv in the application path or else the old legacy i/o VIs won't work correctly.
Message 17 of 17
(969 Views)
