closing .net and active-x references
I'm in a little trouble with "close reference.vi".  Suppose, I have an active-x or .net references, and:
  • When do I have to close these references?
  • Do I have to close them?
  • What does happen when I close them?
  • What could happen if I dont close them?
  • All Opened references must be closed?
And an example:
Suppose, I have a .net / active-x ref. and an invoke/property node call returns a new reference. Can I close the parent reference earlier then a called reference?
I have many questions about this topic, so I think the best could be if someone suggest me a good topic e-book or community blog maybe I can find some useful advices!
Thank you so much!
+++ In God we believe, in Trance we Trust +++
[Hungary]
(3,198 Views)
  • When you done wlith it.
  • Yes.  You do.
  • Release allocated memory.
  • Could casue memory leak.
  • Yes.
And an example:
Keep parent ref open, until all child ref closed.
See LabVIEW menu.
George Zou
(3,191 Views)
I have seen it stated that if the reference number does not change between instances of an application, it does not need to be closed.  I have seen it where certain property node references do not change.  What or how it is determined to use the same reference number, I don't know.  But I have gotten into the habit of closing them anyway.  Your parent reference should be the last reference closed (close them in the reverse order they are opened).
Perhaps someone else can better explain how reference numbers are allocated and why some don't change and others do.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(3,181 Views)
All ActiveX and .NET references should be closed - even ones that you do not explicitly open, such as references returned by ActiveX and .NET property nodes.  References to LabVIEW items - such as front panel controls - do not need to be explicitly closed.  See this discussion for more information: http://forums.ni.com/t5/LabVIEW/Which-references-need-to-be-Closed/m-p/307175
(3,165 Views)
