closing the VI after execution under conditions
Hello.
In my program i have a button that opens new window to show graph from saved file.
In the new window there is i dialog. If user chooses file to open, then the graph is presented in the VI.
I want to make, that if the user cancel the dialog box of choosing file, the new window will close.
What is the solution?
(3,281 Views)
Hi Tacchi,
usually a subVI's FP is closed when the subVI exits (when the VI properties are set properly, OpenOnCall and CloseAfterwards).
The other option would be a property node of the VI to close the FP programmatically.
When you use the standard FileDialog function you should also check the error output for an "User Cancel" error to recognize  a cancel operation of the user...
Message Edited by GerdW on 03-10-2010 03:37 PM
(3,270 Views)
GerdW wrote:
Hi Tacchi,
Hello.
That is what i was thinking about. But where I can find the VI property node?
(3,258 Views)
place a property node (general)  (you will find this under Application Control in functions palette)
right click on that.  go to select class-->VI server-->VI-->VI
 Then left click on the property, FrontPanel window-->Open
then right click on the node and select " change all to write".
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,247 Views)
