cluster button pressed / 1553 communication
No you posted pictures of your code. I can not fix pictures.
Tim
GHSP
Message 11 of 17
(2,239 Views)
Here is my VI thats written in labview 7. There are additional sub VI thats not attached so the VI might show an error.
Message 12 of 17
(2,230 Views)
The inner small while loops is what im trying to update very second. When a button is pressed it sends that Individual string then jump back in to updating every second.
Message 13 of 17
(2,228 Views)
Why don't you use an event structure with the timeout event set to 1 second?Then, instead of the separate case statements, each would be a separate event.
You can also eliminate all of the writes to the value property node.
edit - your while loop iterates every msec - not every second as you stated.
Message 14 of 17
(2,223 Views)
So do i put the event structure inside of bigger while loop and keep the smaller while loop ? Sorry trying to figure out how to code what your sayin. I understand about putting the cluster buttons inside of its own event case.
Message 15 of 17
(2,216 Views)
Accepted by *E*
An event structure goes inside a single while loop. There is no 'smaller' while loop. The code that you want to execute every second goes into the timeout event.
Message 16 of 17
(2,212 Views)
Thanks for your help that seem to work correctly!
Message 17 of 17
(2,203 Views)
