cluster to dynamic conversion problem
I would like to do a FFT for a sine waveform using TDS 3054B. I get the sine from the osilliscope, which privider the Amp. of 10000 points and X, deltaX step values. I want to draw its power spectrum. How can I connect them? The data type Cluster and Dynamic don't fit each other.
(3,465 Views)
Use the Build Waveform primitive rather than the Bundle Cluster. Although the waveform datatype is basically a cluster, you need to use the special tools to make it.
Lynn
(3,455 Views)
What kind of special device? Can you tell me? I have the full version of Labview. Is it possible to make it?
(3,437 Views)
I thought Lynn was pretty clear: Use the Build Waveform primitive rather than the Bundle Cluster.
It's on the waveform palette.
(3,429 Views)
Yes, I got it. Thank you two!
(3,419 Views)
