cluster typedef red coercion dot with property node value
Hi!
I have a larger project, where I do parallel DAQ and other calculations. In the project I pass all of my relevant data between different parts of the program using a cluster typedef control, so if I need to add new element, it updates everywhere in my project. My problem is, when I want to update the elements of this typdef control on the GUI regarding to the changes at different places in my program, I use property node for this. Usually it works, but sometimes I get a really strange behaviour...sometimes the enum element does not get updated, and so on....
I have attached a simplified version, only including the relevant part...
Any idea what I do wrong?
Thanks very much!
(3,353 Views)
just one more thing: What I have found on this NI forum about typdef controls and property nodes, that it is not advised to use property nodes with typdef controls. So now I revise my project, and I try to update my GUI typedef control at only one place in my code just simply connecting to the data flow. But my question is still:
if in LabView the typedef controls and property nodes (write) are not totally comaptibles then what should I use if I want to update the GUI typdef control from different places in my code not directly connected with dataflow?
(3,345 Views)
Accepted by Blokk
The attached file and picture shows a way to write to the control with property nodes.
Run the program. You can change the "Current GPIB subvi" selection or select a control (via Index) and set it's value.
You could use a type def enum to select the desired control if you know the order of controls will not change.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,315 Views)
I got it 🙂
Thanks!
(3,309 Views)
