co-ordinate values from a scanned image
make data from a graph in the paper(scanned image). e.g. xy plotter or 3 axis graph
"Thanks with regards "
by
..........Gireesh..........
(2,312 Views)
I got a frequency response plot in a paper. How to get the data from this as a reverse application of response plotter
by
(2,311 Views)
It just so happens that I've been working on a VI to identify points in an image and output their co-ordinates.
You'll need the IMAQ Vision module for LabVIEW to make it work.
If your data is a set of discrete points on a white background (without grids) then this will work. It won't work if your graph is a continuous line, but you may be able to do something similar using "IMAQ local threshold".
Doing some math on the co-ordinates of points in the image should give you the graph values, but you might want to play around with the code a bit since I made this for a completely different purpose.
(2,293 Views)
