coersion dots and Strict Type Def
I have created a Strict Type Def cluster with boolean indicators.
I am unbundling the cluster and wiring some of the unbundled outputs to a subVI that I created. This subVIs input is connected directly to the Selector input of a the Append True/False String function.
This works, but I am trying understand why there is a coersion dot at the when the output from the cluster is wired to the subVI. Is the reason because the cluster is a Strict Type Def?
If I wire the unbundled output of a regular cluster then no coersion dots appear.
Message 1 of 9
(3,834 Views)
Hello nyc,
Can you post an example VI and cluster to illustrate the issue?
This way I can try to reproduce your issue.
Thanks in advance!
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 9
(3,818 Views)
Accepted by nyc_(is_out_of_here)
Turn on your help window,
Switch to the wire tool,
Float over the wires and compare what you see in the help window.
I suspect type-def to non-typed def is being enunciated by the cooecion dot.
set rant = True
That scenario is one of the reasons I freak-out over the rumour that coercion dots imply a buffer copy. They do NOT. LV is only telling you it is doing something to the data representation and want to let you know about it.
Done ranting,
Ben
Message 3 of 9
(3,797 Views)
@ThiCop wrote:
Hello nyc,
Thanks in advance!
I have attached the Strict Type Def cluster control, the subVI, and the main VI.
Edit: I had forgotten that the boolean controls in the cluster were Strict Type Def booleans. My bad.
As an experiment when I disconnected the boolean controls from the type def, the coersion dots went away.
Message 4 of 9
(3,791 Views)
set rant = True
Done ranting,
Ben
 I had forgotten that I had made the boolean controls in the Strict Type Def cluster to be Strict Type Def boolean controls. Once I disconnected them from the Type Def, the coersion dots went away.
Message 5 of 9
(3,788 Views)
But a coercion dot can indicate a buffer copy....
Did I get you freaked-out ? 😉
This is indeed a very common misconception...
Red dots seem to make some people panic... 🙂
Kind Regards,
Message 6 of 9
(3,770 Views)
as CAN a wire fork but there are no red dots there. so again
"Coercion is not equal to buffer copy"
The only valid way of seeing if a buffer is copied is;
Tools >>> Profile >>> Show Buffer Allocations
Show me a situation where there is a buffer copy and SHow BUffers.. does not show the extra buffer and I'll get a SR and CAR filed ASAP.
Ben
Message 7 of 9
(3,767 Views)
Hello Ben,
That's completely true!
I just was trying to get someone to write your statement (about Tools >>> Profile >>> Show Buffer Allocations), without the message coming from an AE 🙂
Kind Regards,
Message 8 of 9
(3,763 Views)
@ThiCop wrote:
Hello Ben,
Smiley Surprised
It not nice to tease the bear. He has a signature and knows how to use it.
Smiley Wink
Ben
Message 9 of 9
(3,759 Views)
