collecting data and storing into an array using a sub VI
I am using a VISA READ function to get measurements out of a DMM.
Every time i run the program i get a different number. Everything works perfect up to that point.
now i have a subVi to be able to store the data one after the other everytime i take a measurement so that i can ultimately insert it into excel.
it is not working as i intend, what am i doing wrong?
(1,082 Views)
Don't wire the constant to the shift register left terminal, because this will empty the SR at each call.
Also, remark that "Read" is actually "Read and initialize". Consider a change to the operation name.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(1,074 Views)
i removed it and still have the same issue.
And about the change to the operation name, what do you suggest?
(1,051 Views)
Accepted by topic author JohmDoe86
  • Please (please!) do not maximize the front panels and diagrams to the screen. Super annoying!
  • Your DMM code does not have a toplevel loop, you should make it a state machine instead
  • Your subVI needs to complete after one iteration, so don't use a stop button
  • The read mode needs the array wired across to be non-destructive
  • Terminals need to be on the toplevel diagram, not inside structures
  • Use a standard connector pane.
  • If you want to just record successive runs to a file, just append to a file. No need for subVIs. (this also ensure that all data collected so far exists, even if the computer crashes later)
  • Use reasonable terminal names ("array" is not descriptive enough.
  • To get an empty array, just do "use default if unwired" in the init case.
  • do. some. beginner. tutorial.
  • etc.
(1,039 Views)
First: wire a true constant to the While Loop stop terminal. Any operation must only be done once.
Second: connect the right terminal to your output (now it's the emptied shift register).
Paolo
(1,032 Views)
