‎02-11-2014 01:02 AM
I want to design to the right icons ,How to design????
‎02-11-2014 02:06 AM
‎02-11-2014 02:21 AM
the left is the original VI and the right is think to change VI
‎02-11-2014 02:29 AM - edited ‎02-11-2014 02:30 AM
Hi tallahassee,
the color ramp looks the same for both left and right.
Instead that blue rectangle changes it's appearance.
What is that box? Is it an intensity chart/graph? Is it a simple color box?
Do you want to rotate the box at an arbitrary angle at runtime or just change the look at edit time?
What exactly do you want to achieve?
Have you read the LabVIEW help on "customizing controls"?
‎02-11-2014 02:36 AM
my project need show Pressure sensing color change , so need design a diamond of color ramp
‎02-11-2014 02:41 AM - edited ‎02-11-2014 02:45 AM
Hi tallahassee,
you either need to learn how to customize controls (like colorboxes or boolean indicators) or how to use the drawing functions for 2D picture indicators!
Why do you need "diamonds"? Using an intensity graph would be so much easier to visualize your pressure readings…
Like this as an example:
‎02-11-2014 02:58 AM
A feeling of pressure measuring insoles
‎02-11-2014 03:07 AM - edited ‎02-11-2014 03:08 AM
Hi tallahassee,
I still don't get the need for displaying diamond shaped fields.
You still might use the intensity graph, but with some more logic to fill more than one (smaller) pixel with a color.
Like this (using chars to depict colors):
ccbaaa
cbbbac
aabaaa
The "b" also forms a diamond, but is displayed using a rectangular display…
‎02-11-2014 03:47 AM
thaks , I am find a EX http://forums.ni.com/t5/LabVIEW/customize-a-color-ramp/td-p/326021, But Not suitable
‎02-11-2014 03:50 AM
