color to temperature
I have to convert a thermo image in scale of colors (RGB). I could get this with IMAQ, but in particulare i have to pass from the temperature pixel valure at a color value. Can somebody help me to find the algorithm in labview please? thank you.
Message 1 of 9
(4,812 Views)
Hi anto,
use an intensity graph with an appropriate Z scale…
Do you mind to present example data and example result?
Message 2 of 9
(4,802 Views)
Gerd,
i think the request is exactly the other way round....
But Gerds suggestion is valid: Please attach an example image and tell us how the data shall look like later on.
Norbert
Norbert
Expert: Geometry
Message 3 of 9
(4,771 Views)
I have tried your idea but I do not need a graph or image result. I need the pixel value in RGB starting by the temperature pixel value that i have as imput.
here an example, I have a matrix with the temperature pixels values and i have to traslate them the RGB value.
Message 4 of 9
(4,730 Views)
http://www.tannerhelland.com/4435/convert-temperature-rgb-algorithm-code/
 I found this code. DO you think is a possible solution? Thanks
Message 5 of 9
(4,728 Views)
Hi anto,
Where is your matrix?
You load a file, then you convert this file to a 2D array of strings. This array is converted to DBL numbers!
For RGB values I would convert to I32 and display them in HEX…
Please provide (small file of) example data and expected result! Your image doesn't help that much…
Message 6 of 9
(4,716 Views)
this is my matrix and i have to convert this temperature values to correspondent RGB values. Then I can plot with IMAQ tool.
Message 7 of 9
(4,677 Views)
Hi anto,
it still isn't a "matrix", it's just a 2D array of numbers…
Please provide that data in a VI, with array values set to default. Do you think we will start to key in all those values manually in an array?
Please also show use the expected result for those data. You didn't supply any equation (or algorithm), how all those values should be converted to a color.
As long as you don't supply such a formula I suggest to connect those 2D array to an intensity graph for a quick look on your data…
Message 8 of 9
(4,662 Views)
Accepted by anto88
I found the solution algorithm here :http://www.tannerhelland.com/4435/convert-temperature-rgb-algorithm-code/
 thanks for your help, have  a  nice day.
Message 9 of 9
(4,626 Views)
