com port settings for RS232 serial communication in labview 6i?
What should be the optimum com port settings for RS232 serial communication? I am using labview 6i and the o/s is windows 2000?
(3,003 Views)
That depends on the instrument or devices you're communicating with. You will need to know the required baudrate, data bits, parity bits, flow control, etc.
(3,003 Views)
Chris is right.
It depends on your instrument.
Check out the posts from today. There are 3 other "serial port" questions that were answered. You may get your answer there.
JLV
(3,003 Views)
Thanks a lot Joe.The communication seems to be working now. Thanks a ton guys !!
(3,003 Views)
