combining analogue video signals
I'd like to do the following: Record a 4 analogue video signals simultaneously via a PCI frame grabber card like the PXC200AF fromimagenation. Then I'd like to combine the four videos into one, so the videos are displayed next to each other and I can save them in one video file.
I also need to integrate Text into the video to display information about what's going on at a given moment.
Can I do all this with LabVIEW? I'm completely new to video processing with LabVIEW, so I don't really know about the posibilities.
Any help is greatly appreciated.
Remember Cunningham's Law
(2,404 Views)
Are you using the NI Vision Development Module?
If so, you could use "IMAQ Image to Image 2.vi" to copy a small Image into a largeer one.
Christian
(2,398 Views)
Thanks for the answer.
I do have the IMAQ Image to Image 2.vi.
The Question is: At what rate does that VI work?
The Way I understand this that VI processes single images only. So if I want to process, say, 24 fps, I'd have to execute the vi 3x24=72 times a second. Is that possible?
I don't know the exact specs of the cameras, but since they're analogue I reckon that the images won't be exactly 1080p.
(2,395 Views)
This is depends at the actual size of the image and mostly at your system's performance. You will have to test it.
With four 1024x768 U8 images it takes about 1 ms at my Windows System (32bit, Intel i5, 3.34GB), LV 2010 SP1.
Christian
(2,388 Views)
I've played around a bit with the VIs. (Except the one you mentioned, as I do not yet have a license for it) Apparently the Video processing in LabVIEW is sufficiently fast... The Computer my Program will run on in the end is a 64-bit, 4GB i5 "Sandy Bridge" system, so I don't suppose I'll run into any hardware problems there. I'll see when- hopefully tomorrow- my Computer arrives.
(2,373 Views)
