"unicode" "format into string"
Using unicode under LabVIEW I'm facing the problem that "Format Into String" does not support unicode.
Does some one have tips or workarounds?
Some details:
  I'm using LabVIEW 2010 with the setting "UseUnicode=TRUE" in Labview.ini.
(2,885 Views)
Hi Peter,
You are correct in saying that "Format Into String" does not support Unicode.  I assume you would like to convert an ASCII String into Unicode.  If you follow this link, there is "A List of Tips and Tools for using Unicode in LabVIEW".  It is very well documented and should answer any questions you have.  There are attachments at the bottom of the page that provide code and examples too.
I hope this helps.
Lewis Gear CLA
LabVIEW UAV
(2,862 Views)
