combo box choose several
Hello
I try to make a combo box, where it should be possible to choose several values at the same time. The item list contains a bunch of historical traces and I want to do a graph showing only the chosen ones. Is ther any possibility to set a bool for each item, which is per default false and can be changed to true, so this plot is shown in the graph?
thanks
manuelwaser
Message 1 of 8
(3,772 Views)
Using property node of the graph you can. Property 'active trace' and 'trace vible', active trace to choose wich one and visible set to true or false to be visible or invisible (hidden ?). But in beginning you should transfer all traces to the graph.
Hope it will help you
Greg S.
CNRS
LV 7.1 8.2 8.6 2009 2011 2012 2013 2014
LPMC - CNRS
N'oubliez pas de complimenter cela fait toujours plaisir.
Message 2 of 8
(3,769 Views)
A listbox might work better to select the traces you want.
See the attached vi.
list box
Message Edited by vt92 on 04-15-2009 09:27 AM
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 3 of 8
(3,764 Views)
thanks for your help
sadly this does not work
@gregory 45: I can not find "active trace" in the property node from the graph, either not in the one of the combo box.
@vt92: sadlz I can not use zour added vi, because I run LabView 8.6 and your vi is built with a newer version.
Message 4 of 8
(3,733 Views)
Here come an example for trace visible or not on graph.
Greg S.
CNRS
LPMC - CNRS
Message 5 of 8
(3,728 Views)
thanks again.
but this is not what I want. I have a long list of signals. It should be possible to choose several channels and show them in a graph. I already can create either a combo box or a listbox with the names of the channels. What now is my problem, is to show only the chosen channels.
Message 6 of 8
(3,724 Views)
Accepted by TobiasMeier
Here's the vi saved to LV 8.5
Message 7 of 8
(3,709 Views)
thanks all
it now works fine
Message 8 of 8
(3,702 Views)
