combo box
Hi Phil_
I have tried with reading the excel spread but i am not getting it......... Here is the VI which i have tried......could you please help me. Thankyou in advance
Regards
Pratheek
Message 11 of 12
(647 Views)
Things I would change:
  • Be careful when using 'use default if unwired' tunnels. It looks like you want to wire that string array across between both shift registers.
  • Local variable abuse! This program does not need any local variabls, use wires and shift registers instead!
  • unwired controls outside the loop will only be read once, at the start of the program. Put them inside the loop, or inside the associated event case.
  • Use the error wire to enforce execution order rather than stacked sequence structures. It makes the code easier to read.
Message 12 of 12
(624 Views)
