command that should be sent to pen drive to detect using labview
hi,
I want to access my pen drive in Lab view 8.5.I tried it using VISA Read/ Write Functions.But i dont know what commnd i should send  to it so as to get reply. (I used *IDN?.....din't work)I know that PC communicates with USB device using commands or using binary commands.please tell me from where i'll get command set please.
Thank you
GAK
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,028 Views)
What exactly do you mean by "access".
Can't you simply use plain File IO functions?
(4,023 Views)
hi,
i want to access a file from pen drive....any file.for e.g. say word file.And first i want to detect if pen drive is connected or not.
how can it be possible?  is it possible by FILE I/O functions?
thank you
gak
Gaurav k
CLD Certified !!!!!
(4,013 Views)
Accepted by Gak
With the function 'List Folder' you can get a list of all drives on your computer if you feed an empty path to it.
folder names contains the names of the folders found in the specified directory. This function sorts the folder names alphabetically. If path is an empty path, folder names contains the names of the drives on the computer.
Good luck,
Ton
My LabVIEW Ideas
(4,003 Views)
hi
thank you very much.It is what i needed.
gak
Gaurav k
CLD Certified !!!!!
(3,983 Views)
