communicating with window ce
hi,
im still new with labview. i want to connect my device that using windows CE to a host computer. i might want to use autosync, and it is possible as i dont have the labview mobile module?currently i just using labview 12.0. do i need to have external target such as visa? i want to obtain the mac address from the device.thank you
(2,775 Views)
If you don't use mobile module, you need to write another program to run on CE and acquire the data you want, and response to host. Communication media could be either LAN (TCP/IP) or serial (VISA).
(2,774 Views)
hi, thank you for replying.
so i should create a program that should work on CE? i've searched about the mobile module. is it already discontinued?can i just communicate the CE unit to another host PC just using TCP/IP just like communicate through SbRIO?
thank you.
(2,758 Views)
