hi whant to update the changed value at out put of same variable used at the input. how to do that thanks in advance
hi,i whant to update the changed value at out put of same variable used at the input. how to do that thanks in advance
(2,717 Views)
You can use local variables. But beware of race conditions
(2,703 Views)
Can you give an example of what you are looking for?  Because it is sounding like you are trying to avoid data flow, where the wire is the variable.
(2,696 Views)
Can you upload the VI with data required as default value as suggested or some image? Helping then will be much better
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,668 Views)
Accepted by topic author pavithralingareddy
ya i got it. by using property node (and selecting value) we can do it. thans for reply
(2,647 Views)
