communication between parrallel loops
Hey,
I have 2 loops that run parrallel from each other. How Can I communicate between them? I don't want to use local variabeles because then I must create a Indicator.
Pieter
Message 1 of 23
(7,556 Views)
Queues, notifiers, LV2 style globals. Search producer/consumer design patterns, queues, notifiers in the examples.
Message 2 of 23
(7,537 Views)
Hi
There are lots of different possibilities - each with its advantages and disadvantages.
So for instance you can use queues, global variables, LV2-style globals, shared variables, notifiers, ...
This really depends on what you have to do.
You can search either the forums for the mentioned ways or also have a look at the LV help, and you will find lots of information.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 3 of 23
(7,536 Views)
Depending on what type of communication you want there are different ways.
Using queues or LV2 Style Globals (a subvi with shiftregister) just to name some.
Please provide more information on what you want.
Searching the forum (with a search range longer than 7 days) should give lots of answers too.
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 23
(7,536 Views)
You can use queues to communicate between the loops. If you want to ensure that whatever data you send by one should be received bythe other then make the size of the queue '-1'. otherwise use a queue with one element.
BTW, why you don't want to create indicator?
Nudalakasim
Message 5 of 23
(7,531 Views)
Thnx,
I think I have some information I can work with.
I go looking on the site what i can do whit these options
Pieter
Message 6 of 23
(7,528 Views)
Smiley Very Happy ten minutes after posting 4 replies with nearly the same answer.
Henrik
LV since v3.1
Message 7 of 23
(7,524 Views)
Because I thinks it's the wrong way, and you must make the indicator hidden. If you have a bigger program with a lot of communication between loops you have a lot of indicators and it become a mess.
Message 8 of 23
(7,525 Views)
One more off the wall option. Tag values in the DSC engine.
Message 9 of 23
(7,524 Views)
Definitely the most practical solution: files Smiley Very HappySmiley Very Happy
Using LV8.0
Message 10 of 23
(7,513 Views)
