05-09-2012 10:16 AM - edited 05-09-2012 10:17 AM
@Andrey Dmitriev wrote:
That could be great exercise...
That WOULD be a great exercise, but I don't see the *IDN? command anywhere in there, did you delete it from the document? ![]()
@Dennis, I wholeheartily agree but something in my mind (the part that keeps reminding me of the limits of my knowledge) was telling me "Well, I sure don't think the *IDN? command is USB-standard and this guy seems crazy but hey, there are lots of things I'm not an expert on." I was doubting myself, but since someone else agrees with me either I'm not crazy or we're the same amount of crazy. My experience suggests the former may be the more likely.
Shane
05-09-2012 10:36 AM
Shane,
The only place that documents the *IDN? command is IEEE-488.2 (and it's derivatives).
Personally, I would like to see the tutorial on creating a VISA USB driver hidden and only unlocked by users that can prove at least a minimal understanding of USB.
05-09-2012 11:00 PM
Actually all I have to do is to communicate with my device through USB port. So to just check whether I can communicate, I used Pendrive. I was trying to access data from pendrive but I am unable to do it.
05-10-2012 01:27 AM
Sure, you can communicate also with pendrive, but you need to recreate full communication protocol. Is your device uses the same communication protocol as pendrive? Sure, not. There are two modes for communication. Instead of using *IDN? command with pendrive you must use low level I/O, something like this (on given screenshot I perform communication with old USB Scanner):
Andrey.
05-10-2012 02:10 AM - edited 05-10-2012 02:11 AM
USB is a layered protocol interface much like your network interface too. You have the electrical interface which is the USB connector. On top of that the USB communication which in its lowest incarnation is just a bunch of endpoints (addresses) that can be talked to.
This is what you access with VISA USB Raw. On top of that you have many device classes. Such as USB COMM, for message based devices much like RS-232. Or USB Mass Storage for mass storage devices, USB HID for human interface devices such as keyboards, mice or similar, USB Test and Measurement which is similar to the Mass Storage class in the used endpoints but specifically adapted to implement also the IEEE 488.2 commands on top of that. And while it's not to difficult to implement USB T&M in a device, provided you know what you do and have created USB devices already, this interface class is only really used by T&M manufacturers and there also only by a few, usually associated with the VXI P&P consortium.
Each device class has specific endpoints it uses to transport data between the two ends, and specific ways to use the interrupt, bulk and control mechanismes that USB Raw provides. While a USB Mass storage implementation of a LabVIEW driver based on USB Raw could be used as underlaying component to implement USB T&M, there is no point in trying to talk with USB T&M commands (your *IDN? command) with a mass storage device, since it's about the same than if you would talk in Mandarin to someone only understanding English.
05-10-2012 02:29 AM
How do we know what to use for request type and request inputs for both control in and control out vis when we are using a pendrive?
05-10-2012 05:18 AM
Dennis, you know, I agree.
I have the feeling that I've opened a can of worms with my Nuggets. Maybe it's just my perception, but I feel the number of these types of threads has increased int eh last year or so.
05-10-2012 06:30 AM
By reading and understanding the USB specifications! No that is not a goodnight story for children and needs quite a bit of technical background in order to be comprehensive, but such is life. You can't build a skyscraper only knowing how to put Lego bricks together.
05-10-2012 06:44 AM
No! With your Nuggets I've got an idea to develop my own software for the old USB scanner (which is haven't any driver for Windows 7). And it works, I'm happy.
In general LabVIEW - is also can be calssified as "worm" - you can do lot of things with small bricks. The problem what I see - LabVIEW tends sometimes as "black magic box". With several mouse clicks you can easily get great result, but very often the engineers do it without deep understanding - how it works behind.
05-10-2012 08:47 AM
Andrey,
Topic derailment ahead:
What exactly have you implemented and using which software? I'd be very interested to hear more......
