community edition with PXI system
I am considering to acquire a PXI system for hobby use. It is not 100% clear to me what limitation the community edition has regarding to PXI system. I guess the FPGA PXI modules are not supported since community edition does not have FPGA support ? Is there any other limitation ?
In case it matters I mean a PXI 1033 or 1042Q or a PXIe-1062Q chassis.
(1,723 Views)
PXI instrumentations just require the device drivers (incl. chassis) and hence not licensed.
I think RT is not supported in PXI system, if it is just a regular Windows PXI or MXI based PXI, no issue.
Santhosh
Soliton Technologies
(1,693 Views)
Good point.  I have not found a list that tells us what it includes and does not include.  I had to install it on a separate computer in order to observe it.
Community edition is only available in 32-bit.
RT can be run on a PXI controller but I am not sure if that is in the Community Edition.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,689 Views)
Accepted by metebalci
To clarify, RT works on PXI, I meant the RT module may not be part of LabVIEW CE. If the PXI comes with a Windows controller or you will be using the chassis over MXI, it should work with LV CE.
Not sure how it would work if you already have a compiled code for RT but just need to interface it using a regular computer with LV CE.
Santhosh
(1,654 Views)
