compacRIO, Use for Test device?
we are looking for the automatization in a test for devices....Now we are working using like a box with Relays and doing this like manual process...(measuring with the oscilloscope...).
The thing is, we want do the process in LabVIEW...I was thinking about do one program where, using the drivers for the differents device in LabVIEW (oscilloscope, wg...) and with maybe compactRIO, we will have automatic all the process.
Any suggestions? What you think about used CompactRIO?
I am really new in this topic...so I really need help 🙂
Elena
(2,896 Views)
Accepted by elena1428
What you propose as solution is done all around the world many times every day. So yes it can be done and it works very well if you know LabVIEW and what you are doing. We do build many such test systems every year for various clients.
Rolf Kalbermatter  My Blog
(2,884 Views)
I suggest to contact your local NI sales engineer. He can look at your requirements.
Maybe a cRIO is ideal for your case (there is a wide range of cRIOs, from "low cost" to high performance"), maybe you are better suited with a PXI bases system.
Difficult to tell with so little information.
Regards, Jens
Kudos are welcome...
(2,880 Views)
Definately go talk with your local NI rep about your exact situation.  I would also recommend getting some help from an NI Alliance Partner that is experienced wtih Test Engineering, like my employer.
(2,873 Views)
