compactRIO 9076
I'm working with a compactRIO 9076.
I installed drivers and labVIEW.
I receive the error message "Command is not supported by current protocol" and I can't keep working.
In pictures I show you my current situation.
Cristina
(2,069 Views)
Accepted by CristinaOrlando24
Hi Cristina, alhough I don't know for sure why you get this message, I notice that the LabVIEW Real Time module is missing.
This module is needed to program cRIO devices.
Paolo
(2,060 Views)
Hi Christina,
in addition to the missing Real-Time Module your LabVIEW version will not work with this compactRIO.
The last version that supports the cRIO-9076 is LabVIEW 2019.
Regards, Jens
Kudos are welcome...
(2,052 Views)
