compactrio - user interaction from a laptop
I cant seem to find a basic example of what i would like to do
I have been using a producer comsumer loop on a DAQmx system and it worked perfectly - my problem is when i moved my code onto a cRIO 9074 I seem to get locked out Im thinking there is an issue in handling the event structure
are there are examples/tutuorials of how to build a vi on the RIO using a state machine when a user clicks a button that particular state is initated on the rio
Im connecting via a laptop over the network and would like to use the laptop for front end interaction with the user
tks
M
(2,546 Views)
Event structures do not respond to front-panel interaction on real-time targets such as the cRIO, because those systems do not have user-accessible front panels.  LabVIEW allows limited front panel use for debugging and testing, but for a full user interface you'll need to write a separate LabVIEW program that communicates with the cRIO using TCP, shared variables, or another communications method of your choice.
(2,535 Views)
Hey Athes,
I think that this link should provide you with all you need to help you get started:
http://zone.ni.com/devzone/cda/tut/p/id/9988
Regards
Andrew George @ NI UK
(2,510 Views)
