window appearance problem
Hi everybody,
I'm facing the following problem:
I have a VI that calls a subVI. When I call this subVI everything in this subVI works nicely, but I cannot press any button or give any commands in `the main VI.
So I've tried to change in the window appearance differents behavior and nothing.
is there anybody that can help me on that.
Regards
(3,623 Views)
You need to call the subVI by reference and specify in the invoke node that you do not want to wait for the subVI to exit. This also means that you need to have some sort of messaging between the main and subVI so that if the main VI exits, the subVI will also exit. I assume that you simply want to start a sub task and allow both it and the main vi to run at the same time.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,622 Views)
HI Mark, could you give me a simple example?
Regards
(3,610 Views)
HI Mark, could you give me a simple example about how to use the function call by reference together with the invoke you mentioned...
Regards
(3,579 Views)
I will try to post an example. I was busy on some actual work tasks. In case you didn't know many of the users here are not NI employees and we are here on a volunteer basis. So, we do have balance our time here with our real jobs.
Mark Yedinak
LabVIEW Champion
(3,575 Views)
Take a look at the example "Programmatically Controling VIs->Dynamically Loading and Calling VIs->Client - VIServer Example.vi". You can find teh examples under the Help menus. Specifically look at the section of code which says "Launch the Server vi on each Machine" and the subVI "Launch Server". You can ignore the part about getting a server reference to the specific machine. You will not need that. If you leave the reference for the "App.Dir" and the Open VI Rerence unwired it will use the current application reference.
Mark Yedinak
LabVIEW Champion
(3,568 Views)
Thanks Mark. It was exactly what I was trying to do.
(3,544 Views)
