compare columns min and max
i am using a code from labview 7.0?
i dont really remember why.
but yes. a stock one will do.
its just a read spreadsheet from array file?
Message 11 of 31
(1,909 Views)
yes. i have to learn how to save my code correctly.
everytime i save them to post here. it goes around and i lose track of where i saved it.
when i have time.ill try saving it correctly.
Message 12 of 31
(1,909 Views)
SInce you are using LabVIEW 14 now, you should replace the file IO with the stock version of  "read from spreadsheet file". Select string from the polymorpic selector and you get all the current functionality.
Since you are immediately converting to DBL, it would be even more reasonable to just read that data into a DBL array.
Message 13 of 31
(1,905 Views)
ok
Message 14 of 31
(1,901 Views)
Try something like this.
If you don't want to show the ignored columns, simply conditionally build the array instead (LabVIEW 2014 has the conditional output tunnel ;))
Message 15 of 31
(1,893 Views)
oh hey..that for loop looks good!
i been trying to write a for loop for the mess i have but it wasnt sucessful.
but your mod code doesnt do what i wanted to initially do?
i am only interested in comparing the highlisted columns??
max/min of row 0,1,2,3,4,5,n
ex:
row 0
max = 23.5
min = 21.3
max - min = 23.5 -21.3 = 1.2? ====== FAIL (>1 =failed)
Message 16 of 31
(1,888 Views)
The current code ignores all columns that would end up with all zeroes.
(If the valid columns are always the same, you could just autoindex on an array of valid column indices)
Message 17 of 31
(1,884 Views)
ok.
ill play with it.
Message 18 of 31
(1,881 Views)
No check again. If a column would end up with all zeroes, it is already ignored.
Message 19 of 31
(1,877 Views)
this is what i see?
its nothing related to what i wanted?
Message 20 of 31
(1,873 Views)
