compare columns min and max
Accepted by super_saiyans
Super_Saiyans,
Does the code I attached have the functionality that you were looking for?  I used the values from your original post rather than the .csv file you linked.  This is not a very memory-friendly VI but should be good for smaller applications.
Running this produces the following FP results:
This VI was made in 2014 so tell me if you have any issues running this or if this isn't the functionality that you were looking for.
Message 21 of 31
(2,247 Views)
yes. thats exactly what i am looking for
thank you.
i am going to studying and learning Altenbach code and clean up my code with a for loop!
thanks for the lesson today.
Message 22 of 31
(2,234 Views)
Jacobson wrote:
This will not work reliably if for example a single value is zero, while we only want to filter columns that are all zeroes.
Message 23 of 31
(2,232 Views)
OK, I had a few mistakes. It seems we need to transpose again for the desired result. Attached is a new version that seems to be closer to the desired result. Modify as needed.
Message 24 of 31
(2,225 Views)
what happened to the mod3 version you uploadeD?
Message 25 of 31
(2,224 Views)
It's right there ^^^ 😄
(I decided to split it into two posts, to avoid confusion with the quoted picture)
Message 26 of 31
(2,221 Views)
YES!!!
THATS WHAT i am looking for.
i like the differences part..
ill try to learn this code.
THANK YOU!
Message 27 of 31
(2,222 Views)
canyou show me how to make the RED object?
Message 28 of 31
(2,217 Views)
right click on the autoindexed tunnel, and click on "Conditional". In this way you get a conditional terminal just right below the autoindexing tunnel, where you can wire a Boolean value.
"ill try to learn this code."
hmm, this is not a good approach during LabView learning. Understand how the code works.  Only memorizing this particular solution will not help you if you get a bit different task later... 😉
Message 29 of 31
(2,201 Views)
Great catch Altenbach.  I moved the not inside of the conditional for loop.  This will make it so the column is indexed every time there is a value that is not zero.  If all values in that column are zero, it will not stop with the conditional and pass the last value into the tunnel conditional which will have to be a false.
I thought I had reasoned through the random zeroes but I should have done some more testing on my end.
Message 30 of 31
(2,192 Views)
