compare data on excel
my problem is, that when i search a 1d array  and a proper value is found labview stops searching. But i need the index of any proper value in the array to compare it with the index of another 1d array i am searching in to extract a value .
Does somebody knows a hint or could my problem be solved in a differnt way?
My original array is a 2d one and i want to extract for example the row, where column 1 and 2  match 2 values i set.
Message 21 of 23
(703 Views)
You posted numerous screenshots that did not come through because the image files are located on your hard drive, and my browser can't access them from there.  If you want to show screenshots, you must attach the image files to your message first, then post the message.  Then you can edit the message and insert the images based on their file location on the NI servers.
It would be best to post a VI, and an example of the data that you want to search, then we would be better able to guide you.
Message 22 of 23
(688 Views)
Message 23 of 23
(680 Views)
