compare two arrays
I have two arrays such as these
Array 1                          Array 2
a      1
a      5                                 a
b      2                                 b
c      3                                 f
d      4                                 g
e      5                                 h
f       6
g      7
g      10
h      8
h      9/
with what i have now i can create an array that lists the matching elements
Results:
a          1
b          2
f           6
g          7
h          8
However, it does not record both sets of a,g, and h, only the first instance. Anyone know how to fix this problem?
Any help is appreciated
Message 1 of 20
(12,533 Views)
Drat posted to the wrong thread
Bill
CLD
(Mid-Level minion.)
Message 2 of 20
(12,522 Views)
OpenG has a search function that returns an array of all occurrences, not just the first one.  That, and a For loop, solves your problem.  If you don't wish to install OpenG, you can make your own function that loops through a 1D array and returns all of the hits.
Jim
Message 3 of 20
(12,504 Views)
So if i dont install open g how would i do this?
Thank you
Message 4 of 20
(12,500 Views)
Accepted by rmarks12
A FOR loop inside of another FOR loop should do the trick.  Have the outer loop autoindex on the search parameters and the inner loop autoindex on the search array.  On a match, add that item to the list.
Message 5 of 20
(12,492 Views)
Im not sure what your saying, sorry. im pretty new to labview.
Message 6 of 20
(12,487 Views)
I just added an image to my previous post to show what I mean.
Message 7 of 20
(12,482 Views)
You're the best! Thanks so much for your help!
Message 8 of 20
(12,473 Views)
That's okay we were all new at some point.  If you have an question about a function in particular you can open the context help (CTRL + H) and over over a function to learn more.  Also here is some free training if you are interested.
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
-DAQ Application Tutorials
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
With questions on anything else, feel free to do what you are already doing, post here on the forums.
Message 9 of 20
(12,447 Views)
Hi, is there anyway you can post this except for labview 2013??? I can't open your 2014
Message 10 of 20
(12,231 Views)
