compare two data
Hi I want to compare two numerics entered through numeric control a,b. If a=b then i want to see "RAM" , if ab then i want to see "JADU" in the indicator.in the front panel.I am using labView version 13. Please suggest Best Regards Supriyo Senapati
Message 1 of 16
(7,350 Views)
If they are integers, just use an equal comparison and a case structure. If they are floating point (e.g. DBL), all precautions of comparing floating point values apply.
Message 2 of 16
(7,340 Views)
Try something like this:
Message 3 of 16
(7,337 Views)
Thank you sir. I am trying it.
Message 4 of 16
(7,280 Views)
You could also simply use a select node and two string diagram constant.
Message 5 of 16
(7,277 Views)
Sir, my actual message did not posted clearly. I don't know why it happened. My actual message was like that -
I want to compare two numerics entered through numeric control a,b. If a=b then i want to see "RAM" , if a<b then i want to see "SHYAM" , if a>b then i want to see "JADU" in the indicator.in the front panel. I am using labView version 13.Thanks. Regards Supriyo
Message 6 of 16
(7,270 Views)
Check the concept on this link Nested Case Structure.
Message 7 of 16
(7,254 Views)
In another thread, Christian suggested something that I really think would apply here.  Subtract a and b and wire the result directly into a case structure selector terminal.  Set the first case to be "..-1".  This case will be for when a < b.  The next case will be "0" (for a = b) and finally "1.." for a > b.  Of course, this works best if using integers.  When using doubles, then you might want to be more careful.
Message 8 of 16
(7,223 Views)
Well, that's not that different. If this is giving you problems, you should probably start with some tutorials.
Try this:
This is cleaner than case structures, because a single image can show all code ;).
Message 9 of 16
(7,220 Views)
Accepted by topic author supriyasenapati
Most likely you pasted while in HTML Mode and stuff betweeen <> got stripped.
To reproduce, the  paragraph above was pasted below while the edit window was set to HTML, so that's clearly what happened!
Sir, my actual message did not posted clearly. I don't know why it happened. My actual message was like that - I want to compare two numerics entered through numeric control a,b. If a=b then i want to see "RAM" , if ab then i want to see "JADU" in the indicator.in the front panel. I am using labView version 13.Thanks.
Message 10 of 16
(7,207 Views)
