compare
How can I compare many inputs with many constants at the same time and get an output
(3,492 Views)
How should they be compared?  If you want to know if they are equal you can use the "Equal?" function under Comparison.
What are the types of the inputs?  What is the expected output?  Post some code.
(3,485 Views)
Also, be careful if the numbers to be compared are floating point (doubles, ext, etc.) as these can fail a simple = comparison due to the errors inherent in the representation of non-integer numbers in a binary system
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,475 Views)
For eg- I have 10 numbers and I have to compare them with 5 priviously stored number at the same time ...means I have to check that out of 10 number the how many number matches with 5 priviously stored number ...what block should i use for this kind of comparisons in labview?
(3,443 Views)
Hi dey,
any comparison, a loop and some other stuff:
(3,439 Views)
Something like this?
(3,434 Views)
