comparing digital input and output from two different DAQs
I want to create this program where the digital output lights up LEDs at random and push buttons are the digital input part of another DAQ are pushed. When the correct button is pushed, the score will increase by 1. My code doesn't work though. Can someone point my errors to me? Both the DAQs i'm using are USB-6008 DAQs. thanks
Message 1 of 58
(3,927 Views)
Hi Flibberty...,
you can use the "equal?" function to compare your arrays. Both arrays should have the same length, otherwise the result array has the length of the smallest.
Mike
Message 2 of 58
(3,914 Views)
Hi Mike,
 I used the 'equal' function in the event structure but it isn't working.. and could u elaborate more on array size please? I'm utilizing ports P0.0 - P0.7 on both DAQs. thanks
Message 3 of 58
(3,910 Views)
Let's start with the digital output 🙂
What is this code all about?
Do you want only one of the 8 led's to lit randomly or are multiple led's also ok?
Connect the output of the "Scale by power of 2" function or the "Multiply" output directly to the Write DAQmx vi
I don't understand the purpose of the "Boolean Value" and "Replace subset array" thing, so I skipped it 🙂
Message 4 of 58
(3,909 Views)
No you don't 🙂
The DAQmx read is a 32 bit, not 8 🙂
Message 5 of 58
(3,908 Views)
Hi Alain,
I want only 1 LED to light up at each time.. and how do I compare a 32 bit input/output? thanks
Message 6 of 58
(3,902 Views)
Only 1 led, so you should use the "Scale by power of 2" function.
You should also wire something to the 'Timeout" terminal of the event structure.
Maybe 300 and skip the "Wait until next ms Multiple" function.
Now the Time out event will never be run since the default is -1 meaning no time out.
Compare 32 bit? Just like any other compare with the "Equal?" function.
But I don't get the purpose of your code Smiley Sad
The code lit one led ok but then what is supposed to happen?
A user hits the corresponding button or what?
What is the purpose the the "Boolean value" control?
Message 7 of 58
(3,890 Views)
Is this code what you had in mind?
Message 8 of 58
(3,888 Views)
Thanks Alain. That was exactly what I had in mind. I edited the VI to fit into my VI but apparently the button's write function seems to read a little slow.. Is there any way I can change that?
Message 9 of 58
(3,871 Views)
I forgot to attach my VI. Here it is.
Message 10 of 58
(3,869 Views)
