compilation error
Accepted by topic author SaraBaber
Hi Sara
Glad to hear you've solved some of the problems you were having. I've not unlocked any VIs to reduce the load on the FPGA. All I did was change the math from integer to fixed point. This greatly reduced the load because of the coercion dots that it eliminated.
Many thanks
Dan. H
Daniel Harryman MEng
CLA, CPI
Message 21 of 24
(1,483 Views)
Thanks alot!!
really helpful!!
Message 22 of 24
(1,479 Views)
Hello
I tried for the fifth motor and the problem is now same we cannot reduce it anymore!I want to send the code. Shall i be starting it on a new forum or this same? coz its the continutiy!
Shall I post my code here??
Sara
Message 23 of 24
(1,456 Views)
Hi Sara
Please open the issue on a new forum thread as this one has now been marked as solved. It's also a very slightly different issue as you're now wishing to add more code to the program.
Many thanks
Dan.H
CLA, CPI
Message 24 of 24
(1,437 Views)
