compiled stand-alone vi not working
I want to compile my vi so that it works on machines (PC, Mac) that do not have NI LabView installed on them.  My vi connects a laptop to a scientific device via serial/usb connection, then reads data.
SITUATION
My vi works great, when I compile the self-executable application (vi.exe), it works properly on my machine (LabView installed), and when I load it onto another machine (WinXP), the vi.exe loads properly, but it does not run properly.  It only displays COM1 as the available port option (there are more).  When I change the ports around in the Control Panel, so that COM3 is referenced as COM1 (trying to trick Windows), still nothing happens (no data is observed - communication lines are dead).  Alternatively, on the same machine, HyperTerminal shows data streaming from my scientific device using the same serial/usb configuration (no I am not trying to use the vi.exe and HyperTerm at the same time, also I have installed LVRTE851std on said machine - I use LV8.5.1).
QUESTIONS
1) What is wrong with the way LabView compiled the self-executable vi?
2) Do you have any suggestions on how I may troubleshoot this application and get it running on the additional machine?
Message 1 of 14
(4,282 Views)
Your executable will work on a machine with LabVIEW already installed, provided you have the right COM port selected.
However, for the other machines that dont already have LabVIEW, you have to make an installer with the executable.
This way, you have the run-time engine, dependencies, etc all included.
Try this and see if you are still having trouble.
Cory K
Message 2 of 14
(4,279 Views)
Looks like I cannot post an exe to this forum.  that's probably a good thing.  Let me know if there is anything more I can provide
Message 3 of 14
(4,278 Views)
Ok.  Can you elaborate a little more?  How do I make an installer?  Meanwhile, I'll go search the help...
Thanks.
Message 4 of 14
(4,277 Views)
What version of LabVIEW do you have?
Here is a quick guide to correctly building an executable in 8.0 and previous
Look here if you have 8.2 and later
Message Edited by Cory K on 03-20-2009 11:28 AM
Cory K
Message 5 of 14
(4,270 Views)
.... and creating an installer
Cory K
Message 6 of 14
(4,261 Views)
Accepted by topic author CodeMunkee
Message 7 of 14
(4,258 Views)
1) Your code could be used as an example of how NOT to program in LabVIEW. You should definitelly read some book about coding in LabVIEW like this or at least to read The Development guidelines, especially chapter 6
2) Regarding your exe issue - since you are using some VISA functions did you also include the VISA runtime engine to your installer?
LV 2011, Win7
Message 8 of 14
(4,226 Views)
1) Your reply to a 'help' question could be used as an example of how NOT to help someone.  You have bad taste in clothes.  See, style comments get us nowhere.
2) The issue was solved, thankfully by a less rude person, in the message above yours.
Message 9 of 14
(4,217 Views)
You are wrong about 'style comments get us nowhere'. Style matters very much in any programming language and especially in a visual programming language such as LabVIEW. Following the style guidelines makes it easier to maintain and update a program. This is especially beneficial when someone, someday, may have to be responsible for it. Now, if you are a student and this is a one time effort, the style probably does not matter. However, if you are working someplace as a LabVIEW programmer, you will never be taken seriously as a professional until you improve the way your code looks.
Message Edited by Dennis Knutson on 03-20-2009 07:29 PM
Message 10 of 14
(4,205 Views)
