compiling dll for visual basic, which datatypes are ok?
I have a VI routine that performs calculations on greyscale image inputs (represented as U16 2D arrays) and spits extracted parameters out.  I need to send this code to a contract manufacturer, but protect our code from scrutiny. They use Visual Basic as their development environment. Is there a way I can compile the LabVIEW VI into a DLL that they can use and link to in VB? I'm not sure how DLL's handle data structures like clusters. My VI inputs and outputs are listed below, can anyone tell me if I have to make changes so that the VI becomes amendable to being compiled into a DLL?
Inputs:
2D array of U16
2D array of U16
Double
Cluster of
     9 Doubles
     U32
Cluster of
     1D array of doubles
     1D array of doubles
Outputs:
1D array of doubles
Cluster of
     1D array of doubles
     1D array of doubles
Cluster of
     1D array of doubles
     1D array of doubles
     1D array of doubles
2D array of I32
Thanks for your help!
(3,506 Views)
Hi Patrick,
Have you taken a look at creating a .NET Interop Assembly? Here is a link to our reference page regarding converting LabVIEW code to .NET:
Creating .NET Interop Assemblies [article no longer available]
In this page, clusters are specifically referenced:
"LabVIEW converts clusters and enumerations to .NET structures whose elements correspond to the elements of the cluster or enumeration."
(3,463 Views)
