How sort array without using Sort 1d Array?
Anyone can help me how sort array without Sort 1d Array function? Wich sorting is easiest to make in VI and how start?
Message 1 of 22
(11,590 Views)
Bubble sort? Swap value function?
Message 3 of 22
(11,570 Views)
Take your pick. Bubble sort is basic and easy to implement. It was one that I remember from my intro to programming class. Sounds like you have to do the same in your class though you aren't using Fortran and an IBM 360 like I did.;-)
Message 4 of 22
(11,562 Views)
I dont know how insert x' to Array[0] and y' to Array[1]. Some help?
Message 5 of 22
(11,556 Views)
Replace Array Subset.
You may also find the In Place Element Structure more useful for manipulating the array elements.
Message 6 of 22
(11,513 Views)
Why that doesnt work? ://
Message 7 of 22
(11,481 Views)
You only coded the inner loop of a bubble sort where you bubbled the single largest value to the end.
There is another loop outside of that that works on ever smaller sections of the array.
Message 8 of 22
(11,447 Views)
Ok i done. Anyone can tell me is ok?
Message 9 of 22
(11,434 Views)
Why don't you tell us if it is OK - put some test data in and see if it comes out sorted or not. You could even run your algorithm alongside the Sort 1D Array function and check you get the same result.
(blog)
Message 10 of 22
(11,427 Views)
