compression of simx cd vi's
Is there a particular reason some SIMX CD vi's show up in my WINDOWS 7 EXPLORER as being compressed?  For example, see the output below from the cmd.exe compact command:
Listing C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\addons\Control Design\_Implementation\SIMX CD Discrete Stochastic State-Space (External)\
 New files added to this directory will not be compressed.
    24319 :     24319 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External).ctl
    10025 :     10025 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External).xnode
    40532 :     36864 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_AdaptToInputs.vi
    26889 :     26889 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_Bounds.vi
    29761 :     24576 = 1.2 to 1 C SIMX CD Discrete Stochastic State-Space (External)_BuildPopup.vi
    28975 :     28975 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_cfgCallbacks.vi
    37450 :     32768 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_Compare.vi
    25862 :     25862 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_DisplayName.vi
    35938 :     32768 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_DoubleClick.vi
    31803 :     31803 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_Feedsthrough.vi
    36399 :     32768 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_GenerateCode.vi
    27975 :     27975 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_GrowInfo.vi
    34119 :     28672 = 1.2 to 1 C SIMX CD Discrete Stochastic State-Space (External)_Help.vi
    16534 :     16534 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_HelpMap.vi
    26200 :     20480 = 1.3 to 1 C SIMX CD Discrete Stochastic State-Space (External)_Image.vi
    30113 :     30113 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_Initialize.vi
     7923 :      7923 = 1.0 to 1 C SIMX CD Discrete Stochastic State-Space (External)_L10N.vi
    39218 :     39218 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_Message.vi
    44461 :     40960 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_ModeSelect.vi
    43162 :     43162 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_SelectPopup.vi
    35619 :     32768 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_Size.vi
    27764 :     27764 = 1.0 to 1   SIMX CD Discrete Stochastic State-Space (External)_Terms.vi
    28414 :     24576 = 1.2 to 1 C SIMX CD Discrete Stochastic State-Space (External)_UpdateState.vi
Every other vi is compressed.  I attempted to decompress them & it appeared to work, but then it reverted back.  This also happens in some other directories as well, but this is a representative example  Again, I used the command COMPACT which the following link provides:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/compact.mspx?mfr=true
(2,577 Views)
Just to be sure, is this an NTFS formatted directory?  Also, are you attempting to decompress the individual files themselves, or the folder at once?  Per the documentation, changing a folder compression state doesn't always affect the compression of the files within.  Have you tried the command that should compress/uncompress every file on a specified volume?
(2,541 Views)
Accepted by tsunami
I think I found the solution.  I was unaware that ther was an option for compression within PROPERTIES for a particular folder.  All I have to do is check/uncheck the option as long as I permissions that allow it.
(2,531 Views)
