configure audio output graph date and time
How do I configure labview to correctly identify the two circles below?
(3,788 Views)
(3,786 Views)
Hi Lavalava,
Try right clicking the graph in the grey space.  Go to X Scale>>Properties>>Scales.  At the bottom there will be a check box label "Ignore waveform time stamp..".  The default for this is checked.  Unchecked this and you should get the correct time.
Justin P
Justin Parker
Product Support Engineer
(3,756 Views)
(3,732 Views)
Hi Justin,
It was already greyed out.  This only happens whenever I'm in playback mode, in RT mode, I didn't have any problems.  Any other suggestions?  Thanks
(3,730 Views)
Why do you use a chart?
 If you want to avoid the time stamp at the bottom of the chart, just pick an XY graph, for playback mode:
* take the time stamp when the measurement starts
* set the loop speed as a constant
* count the loops and convert to seconds/minutes/hours (etc)
* add the time to the signal --> X
Done, can't be that hard....
(3,718 Views)
I've already solved this problem, thanks though.  All that I did was unbundle and bundle the waveform again.  The only difference is I replaced all t0 with "get date/time in seconds" block.  It works.
(3,694 Views)
