sample value below threshold value
Hello,All
i have array of waveform samples,how can i find the samples which is less than a specific  threshold value?
i would be very happy if you show me by a vi ,please?
thanks
(3,499 Views)
One of the shipping examples that has been around forever is called Separate Array Values. It does a comparison to see if an array value is less than 0. Just change the comparsion function and add a threshold and you are done.
(3,488 Views)
Hi tinamoli
I've attached a small VI that should give you a good idea of how to do it. Let me know if you have any other questions, hope this helps.
Regards
Jeremy
Jeremy T
Technical Marketing
NI
(3,478 Views)
