conflict between GPIB and NI-DAQ
I have a NI-DAQ card, which works well individually. But when I add GPIB to the computer, NI-DAQ does not work, why?
(2,541 Views)
Which DAQ device do you have and which version of NI-DAQ do you have installed? Which GPIB device do you have and which version of NI-488.2 do you have installed? How does NI-DAQ not work after you add GPIB? By "adding" GPIB do you mean installing NI-488.2 or installing the GPIB hardware? What operating system are you running? You will need to be more specific with your question and then we might be able to determine the cause of this problem.
Todd D.
(2,541 Views)
DAQ device: NI-6014
DAQ Driver: NI-DAQ 6.9.3
GPIB device : GPIB-PCIIA
GPIB driver: NI-488.2 1.70
Operation System: Windows 98
Adding GPIB device through control panel (Add/Remove Hardware).
If I add GPIB device in control panel, DAQ device does not work. Test resource shows "not responding to base address" .
If I delete GPIB device in control panel, restart computer, DAQ device works well.
Whenever I add GPIB device in control panel, GPIB works well.
Any comments on that problems will be much appreaciated.
(2,541 Views)
