I am looking for examples code about dialog between a PXI system and an external digicode module. Do you have somme??? thanks
(2,522 Views)
Sorry but I am not familar with a digicode module and could not find a specific example. I assume you will be making some kind of digital interface to this module. The examples to use will depend on the type of interface you need.
If it is a dynamic (handshaking, burst, pattern I/O, change detection) then you should use a PXI-653x and will look for examples and shipping examples for this device to do this.
If you only need a static interface then you can use a variety of boards depending on the channel count and any other functionality you might need.
You can get to the shipping examples from the help menu in LabVIEW and search for other examples at the LabVIEW Zone:
http://www.ni.com/devzone/lvzone/
Please let me know if you have any other questi
ons about hardware to interface to your board or where to find examples.
(2,522 Views)
