confusion about Event Structure Timeout case
If I wire 100 to the hourglass symbol for the Event Structure Timeout case, does it mean every 100 ms if not other events occur, what ever is in the Timeout case excecutes?
Message 1 of 12
(18,023 Views)
Accepted by njacacia
Yes.  If you wire a -1 to the timeout value, the timeout case will never execute.
aputman
Message 2 of 12
(18,012 Views)
Yes, this is how it will behave. This means that if you need something to occur every 100 ms, do not include processing for other events in your event structure.
Here is a very simple test to illustrate how it behaves.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 12
(18,003 Views)
Also note that if you constantly trigger other events, the code in the timeout event might never execute, of course. 😄
Message 4 of 12
(17,968 Views)
I realize this is an old thread, but this is true even if timeout is 0? (That's because that events are a queue, and the timeout event is only triggered when the event queue is empty & the wired time has passed? In that way, if you are constantly triggering other events the queue may never be empty.)
Please join the conversation to keep LabVIEW relevant for future engineers. Price hikes plus SaaS model has many current engineers seriously concerned...
Read the Conversation Here, LabVIEW-subscription-model-for-2022
Message 5 of 12
(12,014 Views)
Mmmm... confusion about your post. I don't understand how the queue status is related to the timeout in an event structure.
Can you show an example of what you are doing (or want to do?).
Paolo
Message 6 of 12
(11,993 Views)
If events are happening faster then they can be handled, then the timeout case can't execute.  However, in such a case your program is going to fail anyway, as you queue up unhandled events until running out of memory.
Message 7 of 12
(11,989 Views)
Yeah, I guess what I was also wondering, but failed to write was this -- timeout of 0 isn't some special high-priority event that gets queued up in the event queue. Now after I write that, it feels obvious - if it was, then the timeout case would always be firing.
Message 8 of 12
(11,970 Views)
Note: I think WavePacket is talking about this kind of structure (here found in Messenger Library but usable anywhere).  It is a feedback node of -1 from the Timeout case, and zero from all other event cases.
2022-01-20 15_41_55-Control Server.lvclass_Actor.vi Block Diagram on Messenger Library Demo.lvproj_M.png2022-01-20 15_41_55-Control Server.lvclass_Actor.vi Block Diagram on Messenger Library Demo.lvproj_M.png
Message 9 of 12
(11,956 Views)
Most of my larger programs use similar techniques, except that I use a shift register. Most events decide if a timeout is needed or not, so that output is on the right. Not all are zero.
One very important adjustment to avoid event buildup is to set the event queue to 1 and disable panel locking.
Message 10 of 12
(11,941 Views)
