connect alarm event to an analog output
I work on a LabView 5.1 Industrial Supervision System. I would like to
connect an alarm event (limit alert high and/or low) to an analog
output. The problem is that the system is very locked. I can't add
some Vi's. There is in some alarm configuration (for example in "Alarm
Setup.vi") the possiblity to do this connection.
Nicolas Hrycenko
(2,654 Views)
Nicolas,
I am not exactly sure what you are asking. It should be fairly easy to check to see if a value is greater that some level, and if so toggle an alarm. Are you asking for ideas on how to do this, or are you trying to modify a VI (Alarm Setup VI) and not able to? I have never heard of that VI, so I assume it is not built into LabVIEW. Give us a little deeper idea of what you are trying to do, and I am sure we can help you out.
(2,654 Views)
