invalid dynamic link call to .DLL file when loading MAX
after installing labview 6.1 attempting to load measurements & automation returns the error message "program error your program is making an invalid dynamic link call to a .DLL file. Close" no other options are available. reinstalling does not help.
(2,777 Views)
After you uninstall MAX, use regedit make sure that all registry keys are removed. If not, remove them manually. Now, always make a backup of the registry before you make any changes. This is all I can really suggest because it sounds like something is corrupt in your system. If this doesn't work, you may need to revert to the old reformat to get things up and running. Another thought is to uninstall all NI device drivers and MAX, then install them one at a time. It could be that only one of the device drivers is causing this and you can track down which one it is.
J.R. Allen
(2,777 Views)
