04-22-2010 04:42 PM
hello,
I have these vis and I need to establish a connection between them via internet . in LAN the data is sent . but I don't know how to connect these vis internet.
any help please and thank you very much.
I have a static ip:80.81.xx.xxx
Solved! Go to Solution.
04-22-2010 11:15 PM
04-22-2010 11:48 PM
Here you go
First do this: Go to Tools>Options. Then Select VI Server: Machine Access and place * to accept allow all incoming connections.
Then, do this : Enable Web Server. Change ports according to your requirements or try with default. I normally use 81.
Then the following:
And Finally this:
Here,you can open the VI on the remote PC.
If you want to remotely control the VI through internet, then go to Tools>Web Publishing tool and select your VI, select Embedded option, and allow control. Start the web server on the remote pc and you can control this VI through internet.
Hope this helps 🙂
04-23-2010 01:51 AM
hello,
thanks for your reply. for the remote pannel connection manager , it seems like a good solution but not in my case.
and for the static ip :yes, it is the server's ip. and the client has to connect it to send data( dmm signal---> dynamic signal). someone tell me to try the command ping sataic ip from client PC? and the result is request time out. I think this is the problem and I am going to resolve it so wish me gd luck
04-23-2010 11:06 AM
khaled377 wrote:hello,
THat was good adice you recieved. Non-routing IP are only available on the local net. Your IT department will have to help with the IP and router settings.
Ben
