connenct instrument
Hi! I m new at this site as also with Labview so you might find my question silly..
I have an OTDR instrument (ANDO AQ-7110C optical fiber analyzer) and I want to connenct it with my PC and see its measurements through my pc.
I m pretty sure that I ll have to use the GPIB port to do the physical connection but what else will I need to finally make it all the way?I don t even know if this can be done eventually...
so,a little help here?:-)
(3,174 Views)
Well start with the manual (you are never wrong reading the manual)http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=0CF4QFjAJ&url=http%3A%2F%2Fsuppo...
It looks like you need a IEC to GPIB adaptor.  And there does not seam to be a LabVIEW driver available so, you get to write your own using VISA and the manual
(3,145 Views)
Thank you so much for your instant reply!!! A couple of questions though...what is the purpose of an IEC?I look it up but I didn't manage to figure what it is and why I need it.Also..In case my instrument has driver its self,is there any change for what I have to do?Thank you so much!
(3,104 Views)
I believe page 117 of the document posted in the previous post talks about IEC and GPIB and how they work together. Take a look through that as well asl look at your device to see what kind of connection you need. Also, do you have a driver for your device? If not, as Jeff said above, you will have to write your own using VISA.
Thanks!
Stephanie S.
Application Engineer
(3,063 Views)
What exactly did you lookup and where did you find it. The IEC is simply a European standard similar to GPIB. It uses a different physical connector so unless you've purchased an IEC controller instead of a GPIB controller, simply ignore all references to IEC. The manual says quyite clearly that the instrument has a GPIB (IEEE-488) connector.
(3,054 Views)
Thank you so much people for your answers!
I finally connected my instrument with a GPIB cable to my pc.I m trying now to figure out if they can communicate.So I placed in my block,a ''GPIB write''.
In "address string" I put the address of the instrument.In "data" I put START (manual pg.121).Shouldn't I see something in the instrument so I can see if there is any communication cause nothing happens.Is wrong something with my data?
(3,010 Views)
Have you tried using one of the examples in the example finder? You can do this by going to Help >> Find Examples... in LabVIEW, and then navigating to Hardware Input and Output >> GPIB. There are two examples there -- one using the VISA commands and another that is a simple GPIB VI.
Are you able to see your device in Measurement & Automation Explorer (NI MAX)? If you continue to have trouble, here is an article that might be helpful:
http://digital.ni.com/public.nsf/allkb/A80DBFCCAC36EBDE862562C80058856E?OpenDocument
Thanks!
Stephanie S.
(2,973 Views)
