how to implement two-trigger to start a task
Hi there,
  I have a analog output task to output a waveform. The will not started until the TTL "1" detected from both digital line 2 and 3 from channel 0. In my code, I use a while loop to monitor line2 and 3 until I get high "1" from both lines. It works but I want the analog task started immediately when the line2 and 3 are set to 1. However, using loop to detect the status always has delay. In my application, I want to shorten the delay as possible. Any way to help the problem is welcomed. Thanks.
(2,479 Views)
Hi PKIM,
Would it be possible for us to see your code?
Jordan G.
LabVIEW Product Marketing Engineer
(2,435 Views)
